setting up a new v9 box, and I’m comparing the SSL setup from 4.x (inherited) and noticed that there is a Intermediate CA on 4.x.
Is this needed with x9.3.1 ??
Thanks, I’m new to version 9.
Hi there, I’ve just upgraded from v4.5.10 to v9.3.1 HF3. I had to replace the inermediate CA on my box with a new one from verisign but you will only need to do this if you are using there SSL cert’s (you will need a two part CA if you want your bar to go green).
I also found out from F5 support that there is a bug in 9.3.1 with the transparent monitors which made the TMM crash (mine were doing it almost every hour), this was fixed in v9.4.3 HF2 which I am now running and is working well.
I’ll second the success of 9.4.3 HF2. Running successfully in several environments on at 10+ platforms with no problems since December.
