Interface details
How can I get full details of an interface regarding its usage ? One of the interface not getting monitored while others can with same configuration ?
You need to do a bit more legwork here and provide more details.
You may need to elaborate more on your issue. What do you mean by not getting monitored, are you checking if your enabled interfaces are getting proper traffic, Did you try the below command to see whats the traffic statistics on each interface.
tmsh show net interface
Could you provide more details on the problem please. Do you mean traffic stats of a interface or monitoring if it is up/down ?
