Dear all,
I write a iRule as the following:
when CLIENT_ACCEPTED {
if { [matchclass [IP::local_addr] equals $::Uni_class]} {
pool Uni_first_pool
elseif { [matchclass [IP::local_addr] equals $::CRT_class]} {
pool CRT_first_pool
else {
pool Default_gateway_pool
when LB_SELECTED {
if {[IP::addr [LB::server addr] equals 11.10.10.254] and [IP::addr [IP::client_addr] equals 10.6.3.4] } {
snat snat_uni_pool
elseif {[IP::addr [LB::server addr] equals 11.10.10.254] and [IP::addr [IP::client_addr] equals 10.6.3.5] } {
snat snat_uni_pool
elseif {[IP::addr [LB::server addr] equals 10.10.10.254] and [IP::addr [IP::client_addr] equals 10.6.3.4] } {
snat snat_crt_pool
elseif {[IP::addr [LB::server addr] equals 10.10.10.254] and [IP::addr [IP::client_addr] equals 10.6.3.5] } {
snat snat_crt_pool
else {
snat automap
however, that genertat some errors when I update with Webgui, just like the picture, I don’t know what is wrong, thank you for you help!
hoolio
2
The error indicates you were using ‘snat pool snat_crt_pool’. The command to specify a SNAT pool is snatpool (without a space).
Can you try this if you want to use SNAT pools and automap?
pool Uni_first_pool
} elseif { [matchclass [IP::local_addr] equals $::CRT_class]} {
pool CRT_first_pool
when LB_SELECTED {
if {([IP::addr [IP::client_addr] equals 10.6.3.4] or [IP::addr [IP::client_addr] equals 10.6.3.5]) and \
[IP::addr [LB::server addr] equals 11.10.10.254]}{
snatpool snat_uni_pool
} elseif {([IP::addr [IP::client_addr] equals 10.6.3.4] or [IP::addr [IP::client_addr] equals 10.6.3.5]) and \
[IP::addr [LB::server addr] equals 10.10.10.254]}{
snatpool snat_crt_pool
snat automap
Aaron
thank you very much Aaron, I will try that!
hey Aaron,
I have tried that iRule, It should now include the “\”, the following is okay :
pool Uni_first_pool
pool CRT_first_pool
else {
when LB_SELECTED {
if {([IP::addr [IP::client_addr] equals 12.10.10.1] or [IP::addr [IP::client_addr] equals 12.10.10.2]) and [IP::addr [LB::server addr] equals 10.10.10.254] } {
elseif {([IP::addr [IP::client_addr] equals 12.10.10.1] or [IP::addr [IP::client_addr] equals 12.10.10.2]) and [IP::addr [LB::server addr] equals 11.10.10.254] } {
else {
snat automap
hoolio
5
The backslash just escapes the newline character and allows you to break up long lines. Functionally, you can remove it with no difference.
Aaron
