Integration with two-factor authentication system
I have a customer asking us to integrate the FirePass with our product - one-time password authentication system. How can I do it?
Regards
Magpies
The FirePass client API is a Windows control that will allow you to establish a communication channel through one of your “favorites” (either a VPN or AppTunnels). This is analogous to connecting to one of these through the web browser except that you can control it programmatically. Currently, we only support username/password authentication which is required each time a connection is established.
So, if you need to use your application to control a communication channel between the device your application is running on and a network protected by a Firepass, then you can use the windows control included in the SDK to do this. The FirePass Client SDK includes a sample application that illustrates the usage of the API.
-Joe
