Hi, Looking to integrate with an application, where it displays all the details of an F5devices, f5vips, Active and standby state, pool members & nodes. can someone suggest a good API to integrate with rails.will iControl supports to fetch my requirements? if can i have link where i can get the documentation
iControl is indeed the Api you require… It can be either SOAP or REST. The docs are on this website (You’re half way there already). Under the Wiki
H
