Installing a HF in EM 3.1.1
Did somebody updated Enterprise Manager 3.1.1 to HF4 or HF5?
I can’t find how to upload the iso files on the system.
Thanks,
Hi Carlos ,
In the GUI if you look under Enterprise Management > Repository > Hotfix Image List you should see an import button to upload the hotfix. You should also see that the repository menu will give you access to upload the base software image.
Once you have both the ISO and HF , if you click on the Hotfix Name e.g. HF5(Build105.0) and then scroll to the bottom you should see a Copy/Install button, then it should just be a case of following the on screen prompts.
Hope that helps.
