Hi, I’m trying to install hotfix through iControl API in java. How can i select which volume to install the hotfix on the HD ? Apparently there is no argument to select the volume but on manual installation through the GUI there is a privilege to select the volume.
In tmsh the syntax is - tmsh install sys software hotfix .iso volume
Jeff
Jeff
Thanks Jeff..!
Thanks Jeff..!
