Is it possible to to check if a username has been provided in a POST request? Could this be done via HTTP::username command or would a HTTP::collect be needed to inspect the payload of the request? Would you be able to provide an example of how this might be done via an Irule.
Hi Ralgar1,
to inspect post parameters you have to use HTTP::collect to become able to parse the POST-Request data. The
[HTTP::username]
and
[HTTP::password]
commands are designed to parse HTTP-BASIC authentication data.
You may use the iRule below as a starting point for your own iRule…
when RULE_INIT {
set static::login_max_post_datasize 1024 ; (bytes)
Check for request to login page...
if { [string tolower [HTTP::path]] ends_with "/login.aspx" } then {
Check for POST request to login page...
if { [HTTP::method] eq "POST" } then {
Check for existence of Content-Length header and enforce maximum POST data size.
if { ( [HTTP::header value "Content-Length"] ne "" )
and ( [HTTP::header value "Content-Length"] <= $static::login_max_post_datasize ) } then {
HTTP::collect the HTTP body based on Content-Length header information.
HTTP::collect [HTTP::header value "Content-Length"]
Set variable as signal for HTTP_REQUEST_DATA event.
set extract_login_data true
Complain about request body size.
HTTP::respond 500 content "Request body does not exist or is too large" noserver "Content-Type" "text/html"
No POST request. Ignore the request...
No Login page request. Ignore the request...
when HTTP_REQUEST_DATA {
if { [info exists extract_login_data] } then {
Remove signal variable for subsequent requests on the same TCP connection.
unset -nocomplain extract_login_data
Extract the entire HTTP request body and escape it to become a HTTP::uri string (for easier parsings)
set http_request_body "?[HTTP::payload [HTTP::header value "Content-Length"]]"
Try to parse the username and password value from the HTTP request body.
if { [catch {
set username [URI::decode [URI::query $request_body username]]
set password [URI::decode [URI::query $request_body password]]
}] } then {
Unable to extract the and parse the username and password value from the HTTP request body.
HTTP::respond 500 content "Unable to parse username and/or password from POST data" noserver "Content-Type" "text/html"
return
if { ( $username ne "" )
and ( $password ne "" ) } then {
HTTP::respond 200 content "Username: \"$username\" | Password: \"$password\"" noserver "Content-Type" "text/html"
HTTP::respond 403 content "Username or Password is empty" noserver "Content-Type" "text/html"
Do whatever you need to do with the $username or $password variables...
Event was triggered by another iRule. Ignore the request...
Cheers, Kai
