I have enabled insert_xforwarded oh the Http profile of the VIP.
I wanted to verify the F5 was working correctly. What is the best way to verify packet capture or a logging iRule? any examples would be appreciated.
Thanks,
Brandon
Thanks,
Brandon
the best way to verify that F5 include correctly XFF is irule on F5 side or check logs in App side.
The best way is F5, you have the event:
HTTP_REQUEST_RELEASE : DevCentral - An F5 Technical Community
An triggered when the system is about to release HTTP data on the of the connection. This event is triggered after modules process the HTTP request. So this event trigged after F5 process just before the request is sent to the backend (there is no additional process so the request is not changed anymore).
You can use my Irule:
and in irule set the var like this:
array set app_arrway_referer {
client_dest_ip_port 1
client_cert 0
http_request 1
http_request_release 1
http_request_payload 0
http_lb_selected 0
http_response 0
http_response_release 0
http_response_payload 0
http_time_process 0
So in logs (/var/log/ltm) you will see igress request and degress request (With header added by F5).
keep me in touch if you need more details.
regards
