Insert SSL Session ID
Hi, I’m quite new on F5 Loadbalancers. I need create an IRule in order to read the SSL Session ID from the client side and insert it in the HTTP header from the server side.
Thanks for your help !
You should just be able to do this:
    HTTP::header insert SSLSESSIONID [SSL::sessionid]
Hi Kevîn, Thanks for your answer. I forgot something.. I need to insert in the HTTP Header the Session ID with a prefix “SSL-”. Where do I write this prefix ?
Thxs !
    HTTP::header insert SSLSESSIONID "SSL-[SSL::sessionid]"
Hi, Thanks for your answer !!
