I am having an issue and am hoping for some guidance or a link to point me in the correct direction. Within my Access Policy, I am needing to add HTTP headers when selecting one webtop link. Can I add it with an HTTP_REQUEST irule? That seems to be the most simple and direct way, something like:
if { [HTTP::uri] contains "VendorPortal_test"} {
HTTP::header insert customer "[ACCESS::session data get session.ad.last.attr.extensionAttribute1]"
HTTP::header insert document "[ACCESS::session data get session.ad.last.attr.extensionAttribute2]"
Any guidance would be appreciated.
Thanks,
Mike
If your webtop link is going to a page sitting behind your F5, then you could use your iRule to add headers to the request.
If the link goes to an external site, then I don’t think you’ll be able to insert any headers, as there’s not way for the F5 to intercept the traffic. Even with a 30x redirect too, it wouldn’t force the browser to send the desired headers on the request. You would need to link to a url on the F5 that could proxy the request to the real server so you can inject those headers.
Michael,
Thanks for the reply. I currently have the link running through a virtual server so that traffic is going through the F5. When I look at the traffic passing, I’m not seeing the headers inserted with the iRule above. I am able to successfully get to the link by going to
Michael,
So the user’s request goes to your VIP, and gets proxied to backend site? If you add some logging to your irule, do you see anything in the ltm log? Something like:
log local0. "URI: '[HTTP::uri]'"
log local0. " VenderPortal_Test - Adding headers"
log local0. " Adding 'customer': '[ACCESS::session data get session.ad.last.attr.extensionAttribute1]'"
log local0. " Adding 'document': '[ACCESS::session data get session.ad.last.attr.extensionAttribute2]'"
This could help determine if anything actually happening or not.
look the following link:
ACCESS_ACL_ALLOWED is raised even if no ACL is defined.
set uri [HTTP::uri]
when ACCESS_ACL_ALLOWED {
if { $uri contains "VendorPortal_test"} {
