iNotes irule on asm standalone
Hi everybody,
is it possible to implement next irule(http://devcentral.f5.com/Default.aspx?tabid=108)on a asm standalone machine? If no are there workarounds to reverse proxy the inotes over asm..
Thanks in advance
greets F
p.s. we use 9.4.5
After a quick read over of the iRule I think it should work with ASM on 9.4.5. Do you have the ability to test it?
If the existing rule works and you end up using it, let me know. There are a few optimizations that could be done for it.
Aaron
