Infrastructure as Code: AWS Cloud Formation, Ansible, and F5 AS3 Basics
This is a simple configuration example to show you the basics of integrating Ansible, Amazon Web Services CloudFormation, and F5’s AS3 declarative interface to create an ‘infrastructure-as-code’ BIG-IP implementation. It’s designed to give you the fundamental building blocks, and plenty of opportunity to extend and enhance things from here.
The architecture looks like this:
There is an Ansilbe host, simply a Linux server with Ansible and the AWS CLI tool installed , with a copy of the F5 Cloud Formation repository cloned onto it, and then a short and simple Ansible playbook which we can run. In an S3 bucket (because why not?) we have an AS3 declaration, again using a very simple configuration.
When we run the playbook, Ansible is going to use the F5 Cloud Formation Template (CFT) and data from the playbook to deploy and configure a BIG-IP, including AWS security group objects, etc. Part of the playbook data specifies a URL where the AS3 declaration is available and the post-install processes on the BIG-IP will uses this to pull down and apply the AS3 declaration.
The result is a running, BIG-IP passing traffic to some webservers, configured entirely by two small text files, with no scripting or deep BIG-IP knowledge required.
Although this configuration isn’t production-ready – it should give you the building blocks to create the infrastructure-as-code configuration.
Prerequisites
  • A working knowledge of AWS and a bit of F5.
  • An AWS account
  • An IAM User that has API access and the right permissions
  • A VPC
  • A subnet
  • A Webserver (or two)
  • An Internet gateway
  • An S3 bucket with public access enabled
  • An AWS Key pair
  • An evaluation BIG-IP registration key if you don’t use the Pay-As-You-Go (PAYG) option - either contact your friendly local spiderman F5 account team or request some here
  • Some sort of Linux instance with internet access (I used an Ubuntu EC2 instance – but whatever you are familiar with will probably work – although you will need to substitute the package installer commands of your OS where appropriate)
Getting Started
Enable AWS API Access
If you’ve use AWS primarily through the web console then first create an AIM user for API access and get the secret and key
Make sure the AWS user has permissions (these are probably overkill but will work fine for a demo).
It’s best to create a group to include these policies and then assign the user to the group (or use roles, but this article isn’t about AWS API best practices.)
Configure the Ansible Host
Install and configure the AWS CLI:
$ sudo apt-get install awscli
Install Ansible and the Boto (AWS Python SDK) components:
$ sudo apt-get install ansible
$ sudo apt-get install python-pip
$ pip install boto3
$ pip install botocore
$ pip install boto
Use the API user’s access key ID and secret access key, along with the region your VPC is in, to configure the AWS cli:
$aws configure
AWS Access Key ID [None]: XXXXXXXXXXXXXXXXXXXX
AWS Secret Access Key [None]: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Default region name [None]: us-west-1
Default output format [None]:
Check it works:
$ aws ec2 describe-instances
<some text describing your EC2 instances>
Clone the F5 AWS Cloudformation GitHub repository:
$ git clone https://github.com/F5Networks/f5-aws-cloudformation
Copy the template we are going to use to a ~/files directory – this isn’t really a necessary step for a production setup, and you could use environment variables etc. to get around long paths but it makes the playbook muc easier to read for this demo.
$mkidr ~/files
$cp /home/ubuntu/f5-aws-cloudformation/supported/standalone/1nic/existing-stack/byol/f5-existing-stack-byol-1nic-bigip.template ~/files/.
Set up a directory for your playbooks:
$mkdir -p ~/ansible/playbooks
Configuring an AS3 Declaration
Gather the IP address[es] of your target servers, and the address you intend to use for application traffic
Then use an example declaration  from the AS3 documentation – the declaration below is about as simple as it gets:
   "class": "AS3",
   "action": "deploy",
   "persist": true,
   "declaration": {
      "class": "ADC",
      "schemaVersion": "3.0.0",
      "id": "example-declaration-01",
      "label": "Sample 1",
      "remark": "Simple HTTP application with RR pool",
      "Sample_01": {
         "class": "Tenant",
         "A1": {
            "class": "Application",
            "template": "http",
            "serviceMain": {
               "class": "Service_HTTP",
               "virtualAddresses": [
               "pool": "web_pool"
            "web_pool": {
               "class": "Pool",
               "monitors": [
                  "http"
               "members": [{
                  "servicePort": 80,
                  "serverAddresses": [
Create this as a text file and then create an S3 bucket to put it in, make sure there is public read access to the file, and get the URL for the file
Check that it’s accessible from an internet connected machine
$ curl <your URL>
<your AS3 declaration>
Configuring Playbook Variables
Using the method of your choice, gather the following information
  • VPC ID
  • Subnet ID
  • IP addresses to use for the BIG-IP
  • Source IP restrictions - at least for management access you should lock this down as much as possible.
  • The URL of your AS3 declaration
  • Your AWS SSH key pair name
Create the playbook in ~/ansible/playbooks, in my example I called it “bigip_as3.json “
- name: F5 Ansible CFT AS3
  hosts: localhost
  connection: local
  gather_facts: false
  tasks:
  - name: Run CFT
    cloudformation:
       stack_name: "f5-ansible-cloudformation"
       state: "present"
       region: ""
       disable_rollback: true
       template: "~/files/f5-existing-stack-byol-1nic-bigip.template"
       template_parameters:
          Vpc: ""
          subnet1Az1: ""
          subnet1Az1Address: ""
          imageName:  "LTMOneBootLocation"
          instanceType: "m5.large"
          licenseKey1: "XXXXXXXXXXXXXXXXXXXXXXXX"
          sshKey: ""
          restrictedSrcAddress: ""
          restrictedSrcAddressApp: ""
          ntpServer: "0.pool.ntp.org"
          timezone: "UTC"
          declarationUrl: ""
       tags:
           Stack: "f5-ansible-cloudformation"
There are a number of parameters that the CFT referenced by the playbook needs:
Parameter Name Required Description
Vpc Yes Common VPC for the deployment.
managementSubnetAz1 Yes Management subnet ID.
subnet1Az1 Yes Public or External subnet ID.  Same as management in a single NIC deployment.
subnet1Az1Address No Optional. If you want to assign static IP address(es) in the subnet, type them here. Separate multiple IP addresses with a comma (the first is the Primary IP address, all others are Secondary). Otherwise leave DYNAMIC and a dynamic address is assigned based on the subnet you specified.
imageName Yes F5 BIG-IP Performance Type – see below for more infor
instanceType Yes Size for the F5 BIG-IP virtual instance (m5.large works fine for this)
sshKey Yes Name of an existing EC2 KeyPair to enable SSH access to the instance.
restrictedSrcAddress Yes The IP address range that can be used for management access to the EC2 instances.
restrictedSrcAddressApp Yes The IP address range that can be used for management access to the EC2 instances.
ntpServer Yes NTP server you want to use for this implementation (the default is 0.pool.ntp.org).
timezone Yes Olson timezone string from /usr/share/zoneinfo (the default is UTC).
owner No Owner Tag (the default is f5owner).
costcenter No Cost Center Tag (the default is f5costcenter).
declarationUrl No URL for the AS3 declaration JSON file to be deployed. Leave as none to deploy without a service configuration.
A note on imageName
The imageName parameter selects which BIG-IP image to boot from - you can find a list by exploring the CFT file and looking in the ‘mappings’ section. In our case as we are deploying a single NIC, LTM only configuration I selected “LTMOneBootLocation
. Note you need the actual name from the template not the AMI  - e.g. LTMOneBootLocation not “ami-aa4ea2c9” , as the F5 CFT combines the imangeName with the selected AWS region to select the correct AMI.
Doing this with a free PAYG trial
Doing the same thing with a free trial is slightly easier a but has a small gotcha.
The template for the same implementation is in the payg directory:
~/f5-aws-cloudformation/supported/standalone/1nic/existing-stack/payg/f5-existing-stack-payg-1nic-bigip.templ
ate
Copy it to your
~/files directory
Unfortunately, there is a limit of 51200 bytes for a CloudFormation Template in Ansible – if you run the playbook you’ll get an ugly error along the lines of:
“Member must have length less than or equal to 51200”
So we need to go do a bit of pruning on our CFT – I suggest removing the region AMI mappings for the regions you aren’t interested in:
e.g. find the mapping section of your CFT
"BigipRegionMap": {
   "ap-northeast-1": {
    "AdvancedWaf1000Mbps": "ami-f52e5318",
    "AdvancedWaf200Mbps": "ami-472855aa",
    "AdvancedWaf25Mbps": "ami-88334e65",
    "Best1000Mbps": "ami-65285588",
    "Best200Mbps": "ami-80334e6d",
    "Best25Mbps": "ami-7128559c",
    "Best5000Mbps": "ami-92334e7f",
    "Better1000Mbps": "ami-072f52ea",
    "Better200Mbps": "ami-062f52eb",
    "Better25Mbps": "ami-e62c510b",
    "Better5000Mbps": "ami-8e295463",
    "Good1000Mbps": "ami-63334e8e",
    "Good200Mbps": "ami-062d50eb",
    "Good25Mbps": "ami-b02f525d",
    "Good5000Mbps": "ami-0a2d50e7",
    "PerAppVeAwaf200Mbps": "ami-88cebc65",
    "PerAppVeAwaf25Mbps": "ami-d03f423d",
    "PerAppVeLtm200Mbps": "ami-233d40ce",
    "PerAppVeLtm25Mbps": "ami-7f3f4292"
"ap-northeast-2": {
    "AdvancedWaf1000Mbps": "ami-0f05872fb7d0e05d1",
    "AdvancedWaf200Mbps": "ami-015506735d78469e2",
Delete entire regions you don’t need – that will bring the file size down to a limit that Ansible finds acceptable.
To make PAYG licensing works, you need to subscribe to the software. For the 200Mb Good instance, the subscription page is here:
Click the ‘Subscribe button”
After that all you need to do is
  1. Remove the license parameter
  2. Change the imageName parameter  to
    “Good200Mbps”
Running the playbook
This is the easy part! We use the ansible-playbook command:
ansible-playbook <your playbook>
$ ansible-playbook ./bigip_as3_payg.json
(my PAYG playbook)
or
<kbd>$</kbd> ansible-playbook ./bigip_as3.json
(my eval licensed playbook)
You can then follow the deployment by going to the AWS cloud formation console.
Once it’s up and running you can find the elastic IP address of your new big-IP instance from the cli or AWS console, and use your favorite SSH client and your SSH key to access the BIG-IP, change the admin password and view the configuration - remember AS3 declarations create their own partition.
Hopefully you’ll end up with something that looks like this
So there we have a BIG-IP booted and configured via Ansible using F5’s supported Cloudformation Templates and AS3 declarative API.
Deleting it
You can easily delete the stack using the AWS CLI:
<kbd>$ aws cloudformation delete-stack --stack-name f5-ansible-cloudformation</kbd>
Where can you go from here?
There are number of next steps from here – leave me a comment if you’d like to see a particular one
  • Make the example more robust and repeatable with environment variables and external file parameters
  • Include the backend server creation in the playbook
  • Explore service discovery – so you don’t have to know the IP addresses of the back end servers  - just their tag names
  • Add a security policy to the AS3 Declaration  - an BIG-IP ASM policy can be exported as XML and kept as a (non-editable) artifact in the same S3 Bucket
  • Integrate running the playbook with an orchestration tool like Jenkins
I should also highlight Cody Greens’s more production ready code at https://github.com/codygreen/Ansible. He uses a slightly different (but certainly no less valid) config, and has done a lot more with parameters to make things more modular.
Great stuff Robert. Looking forward to having this in production shortly
Good article. Does AS3 allow to update L-3 objects? so that we are able to update routes or add or remove VLANs?
AS3 is focused on L4-L7 Services. It won’t give you a declarative interface to handle this kind of component. We have another extension for this kind of use case called Declarative Onboarding (aka DO). It provides a declarative API to be able to fully onboard a newly provisioned device (login, vlan, self, routes, ntp, dns, clustering setup, …)
it is available here: GitHub - F5Networks/f5-declarative-onboarding: F5 BIG-IP Declarative Onboarding · GitHub
Documentation is here: F5 BIG-IP Declarative Onboarding Documentation with an example: Example Declarations
As Nicolas said, you want DO for that - Cody Green’s repo above has that integrated into his Ansible example, including the install of the DO component.
Really great stuff Rob !! Looking forward in production deployment soon
