Improve BIG-IP APM VPN speed with TLS dynamic record size
After successfully setting up BIG-IP APM network access, and running it for sometime, you may be looking for ways to optimize VPN speed for your users. This article discusses one way you can do that.
Feature Description
Beginning in BIG-IP 12.1.0, the Client SSL profile includes a feature that enables dynamic record size in TLS. When applied to a F5 BIG-IP Access Policy Manager (APM) network access VPN TLS virtual server, this can improve VPN speeds for your users. It has been found that certain protocols, notably HTTP, show better client response times using this method. For more information on the Allow Dynamic Record Sizing setting down to the packet level, refer to the following resources
Important: Dynamic record size is a TLS enhancement and does not apply to BIG-IP APM network access DTLS virtual servers. Do not enable dynamic record size on DTLS.
When you want to optimize network performance, you must allocate time to tune each configuration to match the requirements specific to your environment. Additionally, note that configuration changes that improve performance may increase BIG-IP system resource (CPU, memory) usage.
Testing dynamic record size on VPN speeds
Having discussed the theory behind the feature, we will now perform tests to see how it affects VPN speeds.
Network bandwidth can vary depending on many factors, for instance, peak vs non-peak hours. When more users are connected to a VPN, download speeds can decrease significantly. It is therefore important to establish a baseline network bandwidth and download speed at the beginning:
Baseline AWS environment
Windows Client (Seattle) -- VPN --> BIG-IP APM (Oregon) --local LAN--> Apache and iperf servers
AWS environment:
  • BIG-IP APM 17.1.0 VE on AWS (F5 BIG-IP VE - ALL modules, m5.xlarge, 1 Gbps, AWS) located in us-west-2 Oregon.
    Note: Ensure you use at least the recommended size (m5.xlarge) and at least 1Gbps on AWS to make sure there are no bandwidth and resource limits.
  • Windows client in located in Seattle
    • Using iperf3 to measure network bandwidth
    • Using curl to download a 377MB apmclient.iso
    • Optional: You can optionally test using the developer tools on your browser. I used firefox; as the results did not differ significantly from curl. They are not included in this article.
Baseline test results
These are measured with all default settings on BIG-IP APM and dynamic record sizing not enabled:
curl download results
Average download speed: 4950k
C:\Windows\system32>curl -k -o null https://10.0.128.23/apmclient.iso
  % Total    % Received % Xferd  Average Speed     Time    Time     Time  Current
                                                    Dload      Upload   Total      Spent    Left  Speed
100  377M  100  377M    0     0  4950k      0            0:01:18  0:01:18 --:--:-- 4988k
iperf3 results
Network bandwidth: 4873 KB/sec
c:\Users\klau\Desktop\iperf-3.1.3-win64>iperf3.exe -c 10.0.128.24 --get-server-output -i 1 -f K -R
Connecting to host 10.0.128.24, port 5201
Reverse mode, remote host 10.0.128.24 is sending
[  4] local 10.0.128.31 port 61284 connected to 10.0.128.24 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  4.33 MBytes  4434 KBytes/sec
[  4]   1.00-2.00   sec  4.67 MBytes  4785 KBytes/sec
[  4]   2.00-3.00   sec  4.86 MBytes  4977 KBytes/sec
[  4]   3.00-4.00   sec  4.77 MBytes  4878 KBytes/sec
[  4]   4.00-5.00   sec  4.72 MBytes  4834 KBytes/sec
[  4]   5.00-6.00   sec  4.78 MBytes  4898 KBytes/sec
[  4]   6.00-7.00   sec  4.87 MBytes  4989 KBytes/sec
[  4]   7.00-8.00   sec  4.81 MBytes  4925 KBytes/sec
[  4]   8.00-9.00   sec  4.71 MBytes  4823 KBytes/sec
[  4]   9.00-10.00  sec  4.82 MBytes  4934 KBytes/sec
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-10.00  sec  48.0 MBytes  4919 KBytes/sec    9             sender
[  4]   0.00-10.00  sec  47.6 MBytes  4873 KBytes/sec                  receiver
Server output:
[  5]   0.00-10.04  sec  48.0 MBytes  4900 KBytes/sec    9             sender
Test 1: Enabling dynamic record size from baseline
Comparing with baseline results after enabling dynamic record size
Baseline: Dynamic record size disabled dynamic record size enabled Percentage improvement
curl average download, k 4950 5272 6.51%
iperf3 network bandwidth, KBytes/sec 4873 5138 5.44%
While this may not appear to be too high on the AWS cloud, there is also received feedback from customers that they see greater improvements in environments, especially in cases where the end-to-end latencies increase.
Implementation strategy and recommendations
As you plan to introduce this in your environment, take note of the following recommendations:
  • Every environment is unique
    Many factors can affect network performance. This can range from VLAN settings (For example. MTU), TCP settings, intermediate network device throttling, and so on. You must perform testing in your own environment before enabling the feature.
  • Implement the feature incrementally for a selected group of users.
    There are different ways to do this. For example, use an iRule to redirect users based on a URL, to a separate virtual server using a different Client SSL profile that has the feature enabled. Refer to SSL::allow_dynamic_record_sizing on Clouddocs.
  • Monitor BIG-IP system logs and resource usage
    After you enable dynamic record size, make sure that your BIG-IP system continues to function as expected by monitoring the following
  • Verify and analyze SSL statistics
    Use the tmsh command in K41057430: Enhanced SSL profile statistics  and check for failures. The SSL Dynamic Record Sizes section should also indicate use of large record sizes.
  • Boosting TLS Performance with Dynamic Record Sizing on BIG-IP
Conclusion
There are a variety of different ways to improve VPN speeds, and this article describes just one. For other options and considerations, refer to K31143831: VPN for business continuity | Chapter 5: Optimizing Network Access VPN.
