Importing SAN certificate issue
Running version 10.1. While trying to import a SAN certificate, I am getting an invalid character message. Any ideas why this is happening? The SAN was exported from IIS (Microsoft Exchange 2010) outlook web app server in pkcs 12 format
Hi David,
Can you try converting the cert to PEM and then import it? This might be a bug in the PKCS12 logic.
sol6549: Converting PKCS certificates to PEM format for use with the BIG-IP
Either way, I’d open a case with F5 Support to check whether it’s a bug.
Aaron
Thanks hoolio. Converting the PKCS to PEM and importing worked.
