importing new 11.6 iso for upgrade from 10.2.4
get this message when uploading iso ---- An error has occured while trying to process your request
We had a similar issue. We winscp’d it to the F5 instead of using the management GUI.
expanding a little - scp the iso (both main image and hotfix) into /shared/images. After the upload is complete, you should be able to finish the installation using the configuration utility
I hope you’ve read the Release Notes for v11.6 and taken a close look at the all the behaviour and functional changes since v10.2.4. Lots has changed and quite a few things no longer exist (bigpipe, HTTP Classes etc.)
Yes, sorry I assumed you knew the images path. We also had to restart the services to get the .iso files to show in the management GUI. This will cause a momentary pause in traffic.
hello.
I have push the 11.5.4.iso file with scp on /shared/images/ on my bigip VE that it is on 10.2.4. I have restarted services but I don’t see the iso 11.5.4 on the management GUI. Same result with a reboot.
Any idea ?
