So we have an existing Geotrust apache wildcard cert for our site. Cane I import this into the LTM? Would that break the existing cert? I’m completely new to certs and I’m not sure what I can and can’t do in that regard. Can I generate a new CSR from the LTM, and send that to a CA without it causing havok?
So it looks like the process is really straightforward. Does it matter that it’s an Apache cert? or does the F5 even care? If that’s all it is, I just need to import the key and the cert and I’m done?
Does it matter that it’s an Apache cert? or does the F5 even care?it does not matter.
Important: The BIG-IP system uses certificates and keys in the PEM format. In BIG-IP versions prior to 10.1.0, all certificates and keys must be converted prior to importing. For more information, refer to SOL6549: Converting PKCS certificates to PEM format for use with the BIG-IP. Beginning in BIG-IP 10.1.0, PKCS12 certificates may be imported without first converting them.sol10167: Overview of the Client SSL profile
If that’s all it is, I just need to import the key and the cert and I’m done?yes.
Great! That seemed to go okay. I did have to import the key first, I notcied that’s not really mentioned anywhere. I tried importing the cert first, then the key and receive an error. I’ve tried the OpenSSL verification on it, but appraently it doesn’t do wildcards, so is there a good way to test that? I want to make sure it’s installed correctly since this is my first shot at it. Thank you guys for all the help so far, I’m really very grateful for it.
Edit: that did actually work. There was an option that OpenSSL didn’t like, but the MD5 still showed up at the bottom and I didn’t see it at first. Looks like it worked fine then. Thanks so much guys, you’ve really helped me out a lot!
