Importing Certificate For HTTPS Termination
i will put F5 LTM to offload Server SSL connetions ( one to one , one VIP to one Server IP ) .
i have the certificate installed on the server with its private key ( trusted Verisign Certificate ) , Can i import this Verisign Certificate to F5 & use in SSL Client profile , or i need to Create CSR from F5 & generate a new certificate Trusted ?
i don’t want users to recevive Certifiacte warning
You can directly import the key and certificate using the GUI. File format should be PEM. Post here again if you need help converting the files from something else. Also, don’t forget to specify the CA/chain certificates in the profile if necessary. Test first!
but i thought that users will receive a certificate warning if Certificate is not Created from CSR taken from F5 box itself ?
No, that is not necessary, it’ll work just fine as long as you have the private key from the server.
