import ucs without cert, key, chain
hello!
I want to import ucs excluding certificate and key part of ucs. Where should I modify?
It should be without f5 mku value.
thanks
Hello,
The solution here : myF5
Regards
I have already seen the information, but after removing the certificate, key, chain, there is no information about ucs import.
If there is no f5mku -K value, ucs import fails. which part should I remove on UCS?
