It sounds like you’re managing bandwidth allocation across multiple links and want to ensure that traffic is distributed efficiently without overloading any single link. Based on what you’ve described, you want to implement a threshold mechanism to switch traffic allocation when bandwidth usage exceeds a certain percentage.
Here are some key points to consider and possible solutions:
iRules and Bandwidth Monitoring: iRules in F5 BIG-IP can be used for various traffic management tasks, but they are typically more suited for layer 7 (HTTP) manipulation rather than real-time bandwidth monitoring and control. If you need to monitor bandwidth usage dynamically, you might need to use other BIG-IP features or external monitoring tools.
Rate Limiting and QoS: You might be able to use Rate Shaping or Quality of Service (QoS) features available in BIG-IP to define policies for bandwidth usage on a per-link basis. These features allow you to set maximum bandwidth limits and prioritize traffic, which could help in ensuring that no single link is overburdened.
Here’s a high-level approach to achieve your goal:
Monitor Bandwidth Utilization: Use SNMP or other monitoring tools to keep track of the bandwidth usage on each link.
Trigger Actions Based on Thresholds: When the bandwidth usage of a link exceeds 80%, trigger a script or an API call to adjust the load balancing configuration.
Adjust Traffic Distribution: Use the BIG-IP API or iControl LX to update the load balancing policies, ensuring traffic is redirected away from the overburdened link.
Maintain Existing Sessions: Configure the load balancer to maintain existing sessions on the current link until they naturally expire or complete, while new sessions are directed to other links.
Try below iRule and modify as you need.
when CLIENT_ACCEPTED {
# Define variables for the different links
set china_telecom_pool “china_telecom_pool”
set china_unicom_pool “china_unicom_pool”
# Example condition: Redirect traffic based on a hypothetical variable
if { [class match [IP::client_addr] equals china_telecom_clients] } {
# Check if China Telecom bandwidth usage is below the threshold
if { [active_members $china_telecom_pool] > 0 } {
pool $china_telecom_pool
# Fallback to China Unicom if China Telecom is over the threshold
pool $china_unicom_pool
# Default to China Unicom for other traffic
when LB_FAILED {
# Handle load balancing failures
# Redirect traffic to the other pool if the selected pool is unavailable
if { [LB::server pool] eq “china_telecom_pool” } {
} elseif { [LB::server pool] eq “china_unicom_pool” } {
