Hi guys.
My client`s BIGIP have following configuration.
VIP : 211.233.44.50:80fastL4 persist(match across service) mypool:80 VIP : 211.233.44.50:443fastL4 persist(match across service) mypool:443
In client`s DNS → about 30 domain mapping on 211.233.44.50 /
In this case.
I`m going to add certificate to ssl-offload about 10 domain.
And other 20 domain → just L4 SLB In the same way as before.
Is it technically feasible to apply SSL-Offload to a domain with a certificate for one VIP and apply L4 SLB for a domain without a certificate?
You can’t add Client-SSL profiles to fastL4 virtuals - they will need to be standard virtuals.
You can add multiple Client-SSL certificates to a virtual using SNI to select the appropriate certificate, but you need to have a default Client-SSL certificate for SNI to present when none of the specific SNI names match. You will also need a serverside SSL profile.
You could use an iRule that snoops the TCP connection looking for an SNI header, and disables the client-side and server-side ssl profiles for passthrough if they don’t match the correct domains, but that is complex, and I think it would be better to go the whole way and just offload everything.
