Implement Link Control.
Hi All,
Am going to implement the F5 Link controller. i need help on this . what requirements required for the F5 Link controller.
we have 4 ISP links & we need to load balance inbound & outbound traffic as well.
so what is requirement please help.
Hello,
Did you already deploy the basic configuration?
do you want to deploye standalone or cluster?
Regards,
Only License, MGMT Hostname configured. further configuration pending.
deployment is in cluster .
i thought link controller was almost never sold anywhere, but well
this is a deployment guide that should get you started
We have around 6 LC in our environment which are used for webhosting.
Inbound:
  1. go to Link Controller ›› Links : Link List >> create ISP links
  2. Creat Link Controller ›› Inbound Wide IPs : Wide IP List >> call you virtual server as pool members
Outbound:
  1. go to Link Controller ›› Links : Link List >> create ISP links (Already created)
  2. Create pool with link IP’s
  3. Create virtual server and call pool for outbound connectivity
Please let me know any more information is required.
Note: For wideip’s you need to have DNS entry
eg: should map to your wideip
Hello,
below a deployement guide:
it is very simple to follow and clear. It is important that you can do it alone by following the F5 documentation. this will allow you to upgrade your competence and subsequently maintain the product.
of course if you have questions or integration issues. I will be happy to assist you.
Regards
