Currently my customer would like to disable Secure Renegotiation in client SSL profile since they found the report from sslab indicated there was a risk of DoS attack in secure renegotiation. May I know if anyone of you had disable this and got any problem in the web application?
Sure you can disable the SSL secure renegotiation, but there are some downsides in doing that.
Article explaining the difference: (if you have some time to read)
Alternative solution with an iRule:
What ever solution you prefer, always best to test in a staging environment before implementing in production. If there’s no staging environment available, try implementing the changes outside peak hours.
Thanks for the answer!
