Been trying to get this to work but the monitor looks to be my issue. I’ve set the exchange IMAP service to use plaintextlogon and is working fine without SPA authentication. I cannot get the IMAP monitor working to bring the pool to healthy.
If I try a simple TCP monitor the pool is marked up but it doesnt work.
I am using BIG-IP 11.4.1 and Exchange 2010 SP3; anyone got IMAPS to work over TCP993?
Hi Rabbit23, v1.3 of the Exchange iApp will automatically create an EAV monitor that supports IMAPS (utilizing curl-apd, which became available in BIG-IP v11.4.1).
Here’s the text of that EAV file. You’ll need to save it as a shell script and then import into BIG-IP, and configure it like you would any other EAV monitor. You will need to disable strictness to apply it to the IMAP pool.
!/bin/sh
These arguments supplied automatically for all external monitors:
$1 = IP (nnn.nnn.nnn.nnn notation)
$2 = port (decimal, host byte order)
This script expects the following Name/Value pairs:
USER = the username associated with a mailbox
PASSWORD = the password for the user account
DOMAIN = the Windows domain in which the account lives
Remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
NODE=`echo ${1} | sed 's/::ffff://'`
if [[ $NODE =~ ^[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}$ ]]; then
node is v4
NODE=${NODE}
else
node is v6
NODE=[${NODE}]
fi
PORT=993
FOLDER="INBOX"
PIDFILE="/var/run/`basename ${0}`.appname_${USER}_${NODE}_ad.pid"
RECV='EXISTS'
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
echo "EAV exceeded runtime needed to kill ${NODE}:${PORT}" | logger -p local0.error
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
/usr/bin/curl-apd -k -v -u ${DOMAIN}\\${USER}:${PASSWORD} -X "SELECT ${FOLDER}" imaps://${NODE}:${PORT} 2>&1 | grep "${RECV}" > /dev/null
STATUS=$?
rm -f $PIDFILE
if [ $STATUS -eq 0 ]
then
echo "UP"
fi
exit
As to why clients can’t connect even when the pool is marked up with a TCP monitor, you’ll probably need to sniff the IMAP traffic to see what’s going on there.
Mike
Thanks Mike
It was a case of RTFM for me. I have found rerunning the iApp template causes a lot of grief as there are many customizations and there are still bugs in the current template. I got this to work by enabling 993 on the VS and having TLS 143 on the back-end to the pool members (only draw back is i can’t re-encrypt / bridge SSL).
I’ll give the EAV a bash.
