Illegal URL Length - with URL extension
GET /XXXXX/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/common/logout.jsp?key=8096710438270224331&st=435a4a112d2d0692934e31b7ebe00e4e&KY1=02cba160 HTTP/1.1 Host: online.abc.com Referer: https://online.abc.com/XXXXX/common/logout_redirect.jsp?key=-1691352645243715963&st=435a4a112d2d0692934e31b7ebe00e4e&KY1=02cba160 Accept-Encoding: gzip, deflate Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8 Accept-Language: ar Connection: keep-alive DNT: 1 User-Agent: Mozilla/5.0 (iPad; CPU OS 9_0_1 like Mac OS X) AppleWebKit/601.1.46 (KHTML, like Gecko) Version/9.0 Mobile/13A404 Safari/601.1
Do anyone face this blocked on F5 WAF? Why this happened?
Check your max URL length setting:
Application Security -> File Types -> Allowed File Types
It’s either
.jsp
or
File Type that matches for this request. Increase the URL length value as needed.
This should solve your problem.
It’s either
.jsp
or
Kindly check the header /XXXXX/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/login.js/common/logout.jsp? It looks suspicious. It is application error but please tell why it is occurred?
That you must check with your application team. Why do you think the error has anything to do with F5? If you want to suppress the ASM violation for such requests, modify the setting I mentioned. Other than that, investigate for root cause in the application. Cannot help you further with that.
I would like to know that what thing in application make such requests. Repeated characters in URL
What was the block in ASM? It should tell you everything you need to fix this.
