Ignore certain cookies for ASM
Hi All,
I am having a problem on our LTM/ASM (ver 11.5.1) box. We use cookie persistence configured on the virtual server. Lately we had to encrypt the persistence cookie for added security. The result is, sometimes the encryption causes the value of the cookie to be some weird characters. And our environment requires that all headers have to meet certain character standard.
My question, is there a way to ignore the persistence cookie (or cookie characters to be specific) on ASM? I know we can ignore the Attack Signatures for the cookie, but we need certain characters to be blocked on Headers in general, but ignored in this particular cookie.
Appreciate any advice,
Thanks,
Kenny
You can accomplish the using Header-Based Content Profiles Adding URLs to a Security Policy
Under the “Header-Based Content Profiles”, there are 3 options
Request Header Name ---> Set a Cookie header. Request Header Value ---> Set a Cookie value. Request Body Handling ---> Set as “Do nothing”
This will have to be configured per-url.
Thanks Tikka!
I’ve got the same answer from F5 support. Case closed
