Ignore a rule
I am trying to create a rule where certain content is blocked from being accessed outside of my site. I tried this rule:
if {[matchclass [HTTP::uri] contains $::restricted_URL_datagroup]} {
Block content
HTTP::respond 404 content “”
But that blocked all the content, including when it is accessed from my site. So I tried this rule:
if {[matchclass [HTTP::host] ends_with “.mysite.com”]} {
Do nothing
elseif {[matchclass [HTTP::uri] contains $::restricted_URL_datagroup]} {
Block content
And that effectively took my entire site down. What would be the proper way for me to write this rule?
What is contained within ::restricted_URL_datagroup?
CB
Something like “/dir/my_content.jpg”
Such that HTTP:uri would be like “/a_dir/another_dir/dir/my_content.jpg”
What about
 if {[matchclass [HTTP::uri] ends_with $::restricted_URL_datagroup]} {
 discard
CB
If I understand the discard statement correctly, that would also block all access to the content even when it is accessed from within my site. I need to make an exception (i.e. ignore the rule) for all content accessed from within my site.
This is really confusing to me. I tried this rule:
if {not [matchclass [HTTP::header “Referer”] contains “.mysite.com”]} {
And it blocked all access to the site entirely. It is as if not including an action just drops the connection altogether. That should not be.
Try something simple first
    if {[HTTP::uri] ends_with "/dir/my_content.jpg" } {
         discard
CB
OviShare, if I understand your initial question correctly, you want the script to allow access to some paths on your application server but not all. Is that correct?
I figured out my problem. This code:
Is incorrect. I should not have been using “matchclass” in this case, and thus the broken code was blocking all traffic.
For posterity’s sake, here is my working code:
set refer_host [string tolower [HTTP::header Referer]]
if { ( not ($refer_host contains “.mydomain.com”) ) and
( not ($refer_host contains “.myotherdomain.com”) ) and
( [matchclass [string tolower [HTTP::path]] contains $::restricted_URL_datagroup] ) } {
Block content
