I have the following problem. I have seen that there are two topic about this but I can not fix it in any way.
The problem is as follows:
I have 2 VS (http and https) - POOL - http node 1 only
What I do is use the HTTP VS the common irule from http to https.
The VS https traffic and takes up the pool after mand.
Everything is oka.
E problem occurs when loading an iframe, is that when I programmed (closed code) requires http put in the iframe generating mixed zone in the famous browsers.
What I need is a irule or some way to convert iframe to https before you open it or is there any way?
If I understand you correctly there is an iframe on a secure page that, but the iframe contents are not secure. This is causing a “mixed content” security alert in the browsers.
Some questions:
Where is the page hosted that is loaded in the iframe?
Is the page that uses the iframe hosted by you?
Is the page that is loaded in the iframe accessible via HTTPS?
Depending on your answers there may be more questions.
In the same site that the VS example : VS: test.com IFRAME : test.com
Yes, is the same site, but i don't have access to the admin of the server.
If i don't have allow http to https all is oka, only when the access is from https the iframe display http and don't load the content. The links is accessible via https is a pdf file.
