Code :
67235
Tested this on version:
12.0
Code :
67235
12.0
I am trying to use this iapp with version 12.0 and get error (01020036:3: The requested customization_group (/Common/SWG_DCAgent.app/SWG_DCAgent_apm_HTTP_401_response) was not found) When trying to create the application.
Hi pkwilly, thanks for your insight. We just uploaded v1.0.3, which should fix the issue you are running into on BIG-IP v12.0. Let us know if you have any additional trouble or questions.
I tried to use this iapp on 11.6.1 but it shows an error
The requested customization_group (/Common/IFmap.app/IFmap_apm_HTTP_401_response_ag) was not found.
Is it not compatible with 11.6.1?
Regards
I got the same error with v11.6.0 HF6
Same error message with 11.5.4 HF6. Any updates on this?
Got this working on 12.1.1.
Is there an older version of this iapp that is compatible with v11.6.1? Or does anyone have any documentation that shows how to manually configure what this iapp does?
