For this application, if an HTTP request doesn’t come in with certain specific URI’s then we want to redirect it to this Content Management front end in the cloud. I tried doing it this way:
when HTTP_REQUEST { if { [HTTP::uri] starts_with “/fmstorefront”} {pool qa.fmmpe-cat.com_80} elseif { [HTTP::uri] starts_with “/medias”} {pool qa.fmmpe-cat.com_80} elseif { [HTTP::uri] starts_with “/fmwebservice”} {pool qa.fmmpe-cat.com_80} elseif { [HTTP::uri] starts_with “/ipows”} {pool qa.fmmpe-cat.com_80} else { HTTP::redirect "; return } }
Now the first 3 elseif could be done better, but this seems to work for now. It’s the ELSE that isn’t working. When I do this right now, I should get a NOT FOUND from the remote site (as its not up yet) but I’m getting “This site can’t be reached”
Any suggestions?
When posting iRule, please use formatting for ease of reading. This is your iRule:
if { [HTTP::uri] starts_with "/fmstorefront"} {
} elseif { [HTTP::uri] starts_with "/medias"} {
} elseif { [HTTP::uri] starts_with "/fmwebservice"} {
} elseif { [HTTP::uri] starts_with "/ipows"} {
HTTP::redirect "https://d2ipxxe5h4s25e.cloudfront.net"
I would recommend using a datagroup like this as there is a common pool for the matches URI:
if { [class match [HTTP::uri] starts_with CLASS_URI] } {
CLASS_URI is a datagroup.
Or use the switch statement.
switch -glob [string tolower [HTTP::uri]] {
"/fmstorefront*" -
"/medias*" -
"/fmwebservice*" -
"/ipows*" {
default {
