if http status not 200 reload balance ?
If http status not 200 re-load balance and don sent any traffic which server not gives http 200 ? I need this I rule :slight_smile:
Hi!
Im just wondering if you can edit your http monitor’s send string so that it can mark the server down that is not returning 200 OK?
Hth!
Czar
Tomorrow I will try and inform you.Many Thanks.
