Hello
I’m wandering if its better to try and use a case statement for this irule, so if the dest ip is in the blacklist we discard, if the source is in $client_sources we send to ingress pool etc.
rule new-rule {
when CLIENT_ACCEPTED {
if { [matchclass [IP::local_addr] equals $::blacklist] } {
discard
} elseif { [matchclass [IP::remote_addr] equals $::client_sources] and [active_members Ingress] >= 48 } {
pool Ingress
} elseif { [matchclass [IP::remote_addr] equals $::client_test] } {
pool Ingress-test
forward
However with case statements I thought they are only useful if the variable is the same. So because I am using 2 different tests i.e. local_addr and remote_addr the case couldnt be used for this?
Thx
