Hi , I have an iRule in which I need to check if the URL ends with “/”, Looks like it’s working for some URL’s but not for all . Any help would be really apprecited. I am adding only a part of iRule.
so if the URL is http://abc.com/, it should go to default pool but it’s going to other pool all the time. The condition is if a URL ends with “/” it should go to default pool:
eg: http://abc.com/ or http://abc.com/xyz/ or http://abc.com/xyz/abc/
Below is the iRule:
if {$retried == 0 && [HTTP::uri] ends_with “/”} { pool $default_pool {pool $lsds_pool } }
