IE choking on exchange iRule
Hello community,
Bit of a strange issue, and it’s most probably an IE bug but I was wondering if anyone had tips on how to mitigate by tweaking the iRule in the Exchange 2013 iApp. We can’t reproduce the problem on other browsers (tested FF, Chrome and Safari), the problem, ironicly is only with IE:
We’re protecting unauthorised access to /ECP. That part works. The problem arises when in the ECP and a user wants to at/change a messagebox rule. This opens up a popup. On IE, the pop up contains the error page, whereas it works with other browsers.
Here the iRule code:
    if { [HTTP::uri] contains "/ecp" } {
    s
    et response "
    EAC Access Denied
    We are sorry, but access to the Exchange
    Administration Center is restricted to approved client IP addresses. Your IP address, [IP::client_addr], is not
    approved.
    if { [HTTP::header exists "Referer"] } {
    if { [HTTP::header "Referer"] contains "rfr=owa" } {
    pool
    my_iapp_2013_owa_pool
    } elseif { [class match [IP::client_addr] equals "
    trustedAddresses
    pool
    HTTP::respond 200 content $response
    unset response
Hi laerm, the popup isn’s using the referer header that we key on to tell us that the request came from OWA instead of EAC. Try modifying your rule to include the URL for the rule editor:
    if { [string tolower [HTTP::uri]] contains "/ecp" } {
        set response "EAC Access Denied
        We are sorry, but access to the Exchange Administration Center is
        [IP::client_addr], is not approved."
            if {[HTTP::header "Referer"] contains "rfr=owa" } {
                pool my_owa_pool
        } elseif {[string tolower [HTTP::uri]] contains "/ruleseditor/editinboxrule.aspx" || [class match [IP::client_addr] equals "exchange_2013_trustedAddresses"]} {
            pool my_owa_pool
        unset response
I’ve found a few more instances where access is denied for resources when the Referer header is not sent. We’ll take care of that in a future version of the iApp, but for now you should redeploy and disable that feature.
very nice post @mikeshimkus
