Idle timeout on OWA https session
Hi, We are in the process of migrating outlook connectivity from LTM v10.2.4 to LTM v11.6.0. One issue we have seen is that OWA sessions through the new virtual server are timing out at 3-5mins. i have compared configurations and can not find any discrepancies so I am wondering if there has been a default between versions which needs to be checked? I have checked some other Dev central blogs and I see some other users with similar issues but I look to have any workarounds in place. here is my irule setting for /owa
"/owa*" {
         Outlook Web Access
        if { [HTTP::header exists "APM_session"] } {
            persist uie [HTTP::header "APM_session"] 7200
            persist cookie insert
        pool outlookeu-owa_pool
        return
here is my persistance profile output ltm persistence cookie outlookeu_persist_profile { app-service none defaults-from cookie timeout 0
My tcp profile idle timeout is also set to 3900 seconds.
Any other idea’s?
The iRule you’re using looks very similair to the ones found in the F5 deployment guide for Exchange 2010/2013. However the iRules on page 87 of this guide shows the command persist cookie insert timeout 0 instead of persist cookie insert.
