Identifying expired certs
Is there a way to identify a) all expired certs and b) certs not applied to any profile?
Thanks in advance,
In the Gui, go to System ›› File Management : SSL Certificate List and that will show you the certs and when they expire. Have not found a way yet to identify unattached certs.
I find it easiest to go to the command line to find things like the unattached certs.
If you just want to see if a cert profile is used, or how many times it is used I have had success with the following:
tmsh show /ltm virtual profiles | grep “ClientSSL Profile: namegoeshere”
Of course you could get a lot fancier but that might get you started…
