In an IRule, how do you list all the active node member addresses in the current pool? We do not want to hard-code node addresses in the iRule.
You can check to see if a specific IP:port is part of a pool and its status using LB::server (Click here), but there isn’t a command to return all members of a pool.
Aaron
