Hi!
Trying to import a key/certificate with the iControl SOAP powershell snapin, but I get these errors:
Exception calling "key_import_from_pem_v2" with "6" argument(s): "Exception caught in Management::urn:iControl:Management/KeyCertificate::key_import_from_pem_v2()
Exception: Common::OperationFailed
primary_error_code : -14 (0xFFFFFFF2)
secondary_error_code : 0
error_string : Keys do not match"
At C:\Scripts\LetsencryptQA\letsencrypt1.1.ps1:418 char:90
+ ... rt_from_pem_v2($ManagementModetype, @($KeyName), @($StringPem), $Secu ...
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SoapHeaderException
And for the certificate
Exception calling "certificate_import_from_pem" with "4" argument(s): "Exception caught in Management::urn:iControl:Management/KeyCertificate::certificate_import_from_pem()
At C:\Scripts\LetsencryptQA\letsencrypt1.1.ps1:441 char:103
+ ... om_pem($ManagementModetype, @($CertificateName), @($StringPem), $true ...
**Importing the key with another name works though**, which would indicate that the key exists somewhere.
However:
`list sys file ssl-key | grep name
Nothing
list sys file ssl-cert | grep name
Nothing
ls -alR | grep name
Nothing
And nothing in the GUI certificate list under any partition.
I have also:
- Done a mcpd reload and restarted the device.
- Manually imported the certificate and key in the Web UI (works, but then I can t reproduce the error)
Any clever ideas?
/Patrik
