iControl + SOAP
Hey all,
Ive written a few iControl java applications and I am now a little familiar with the potential of it all. I want to now explore the webservices part, specially how to call the webservice with a simple client sending a SOAP message. I am using a web application tool called TIBCO to mock up something and hit a brick wall.
Im trying to call get_all_statistics in LocalLB:VirtualServer. The test uses:
URL: https://172.20.178.130/iControl/iControlPortal.cgi
HTTP Headers: =SOAPAction=urn:iControl:LocalLB/VirtualServer
=Content-Type=text/xml
Password: ******
Method: POST
I also tried the URL: https://admin:***@172.20.178.130/iControl/iControlPortal.cgi but no luck.
Am I missing something fundamental?
Cheers,
Naman
At first glance that looks good to me. Are you getting an error returned? Is the result empty? What specifically is the problem you are seeing?
-Joe
Agreed with Joe, the SOAP that you’re showing looks like the request, what are you getting back?
Which TIBCO tool are you using for the mock-up? It won’t modify our answers, I’m just curious because I’ve used TIBCO and their tools are some nice stuff.
Don.
Im using tibco 3.6.0. These are the steps im following
1. I create a new mapping rule and load C:\dev\iControl-9.4.0/sdk/wsdl/LocalLB.VirtualServer.wsdl file
2. Then i select get_all_statistics and click test (attached picture: pic1)
3. I select “test” and it looks like it sends the request but I get a “Service Error”. Im not sure if this is from the F5 or tibco though (pic2)
I dont believe there are any log files for me to lookup. A bit stumped.
If you have a test F5, you can enable http on the iControl http server and then tcpdump the traffic between the client and the F5… You can then see the query & response & work out who’s giving what error (Perls SOAP::Lite has a nice debug facility that shows you all this without needing to snoop, but I don’t know if Tibco does… never used it).
H
