Hi, I was looking for an easy way to quick apply an Irule to a bunch of virtual servers, this is eventually being used to publish a maintenance page on a couple of websites.
So I foooled around with Icontrol a little bit and powershell F5 snapin. Now I’m looking for a script/oneliner which is able to put an Irule on a VS and remove it afterwards.
I tried this way :
ps > add-f5.ltmvirtualserverrule /Common/Irule -virtualserver /Common/Virtualserver
Which produces an error message: Cannot bind parameter ‘Virtualserveritem’ etc
So it looks like this cmdlet isn’t suitable for a oneliner perhaps.
I found out (using Devcentral search) that the F5 management pack provides you with a cmdlet Register-LTMiRule, this would be perfect, however this cmdlet isn’t available within the Icontrol package…
I’m not much of a powershell scripter so is there a oneliner/script available for this kind of purpose?
Best, E
