iControlREST doesn’t seem to be working directly when the user needs to authenticate via TACACS or any other external auth system (11.5.x). I understand that there is a bug id associated with this.
- Does anyone know the bug id ?
- Has this been fixed in any specific code version (12.x) ?
- Any possibility of getting this fixed retroactively in one of the 11.5.x HotFixes ?
AFAIK, iControl REST is not officially supported in releases prior to 11.6.0 so I wouldn’t bet on any bugfixes for the 11.5 branch…
It’s working in 12.1.0,
You first need to get a token from the external auth provider. It’s fully described here in the “About external authentication providers with iControl REST” section :
iControl® REST API User Guide, Version 12.1.0
