iControl REST API access issue for users with guest role thorugh TACACS
Hello All, I have enabled TACACS on F5 LTM running with version 11.6.0 and provided guest role for the users other than the Admin team. Post change for the users with guest role are unable to access LTM using iControl REST API
If anyone has experianced this issue, could you please share the steps to resolve the issue.
Regards, Thiyagu
Try granting these users the role of Auditor, it will restrict the account so they can’t make changes but should still be able to view objects using the API
This role grants users permission to view all configuration data on the system, including logs and archives. Users with this role cannot create, modify, or delete any data, nor can they view SSL keys or user passwords. Users with the Auditor role have access to all partitions on the system, and this partition access cannot be changed.
