ICONTROL Method failure
I am using ICONTROL with POWERSHELL with LTM’s at version 12.x. I am executing the following command and getting an error response:
Command:(Get-((server))
Response: Method invocation failed because [iControl.LocalLBVirtualServer] does not contain a method named ‘get_content_policy’.
Would be easier to answer if we knew what code you were running. Are you running the Powershell script written by Joel Newton? Or something else from github?
No. Home grown over time by pulling together pieces of multiple examples. Basically, I am duplicating the MAP feature, but want to include the policy information.
Ok, I found the answer. All I needed to do was to update the PowerShell iControl DLL’s to the latest version, which includes the get_content_policy method. If I would have looked closer at the documentation I may have noticed that this method is new to version 12.
