iControl for Gtm wideip
i am using iControl Rest 2.4 downloaded from https://pypi.org/project/iCR/.
while using  wideips = bigip.getlarge(“gtm/wideip/a”, xxx) , where xxx is the size of chunk, i would like to understand the limit of chunk size.
if i use wideips = bigip.get(“gtm/wideip/a”) , it works if i have 200-300 hundred wideips, but in case you have +10k wideips it gives you Error 500, AsyncContext timeout.
what is the best way to download via api the /mgmt/tm/gtm/wideip/a ?
I’ve ran into same problem. well I found workaround that api request with these parameters.
/mgmt/tm/gtm/wideip/a?$top=500&$skip=0
$skip is specifies the number of rows to skip in the result set. The result set is chosen from the remaining rows.
$top is specifies the first N rows of the result set.
And you can got a respond with a properties. Well know this properties “totalItems” how many items in wideip list.
I hope it your help
