Can someone tell me what I need to verify as running on my 4.5.10 Combo box so that iControl can discover it?
I have an HA pair and iControl will only discover 1 of the units.
The units are sync’ed and in production.
Also, is this the correct place for F5 support for iControl OR should I be calling support?
Thanks!!
David Pasch
MKCorp
Dallas, TX.
David,
For 4.x BIG-IP, make sure the CORBA Portal and related servers are running. To check their status, you can do a “bigstart status” to see.
To really make sure the portal and servers are running properly, perhaps you should do this:
bigstart restart portal
bigstart startup corbalocallb
bigstart startup corbasystem
bigstart startup corbanetwork
bigstart startup corbamgmt
Loc
David,
By “iControl”, do you really mean “iControl Services Manager”? Loc pointed out how you can make sure all the iControl services are running on a BIG-IP for client applications to connect to. Hopefully his response answered your question. If not and this is indeed a question about iControl Services Manager and it’s functionality, then we do not currently provide assistence on DevCentral for that product and you will have to contact F5 Product Technical Support. The “iControl” here on DevCentral relates to building applications that use the iControl API’s to connect and manage our products.
-Joe
