Hi. I was directed by F5 support to post my question here.
I’ve got 2 Bigip 6400’s running 9.1. I’ve been looking at the samples in the SDK, cause iControl sounds very very nice.
However, when I run the scripts in iControl-9.0/sdk/samples/soap/perl/soaplite/LocalLB, it sends the iControl.cgi process on the Bigip crazy (I tried this on both -- same behaviour on both).
E.g.:
perl LocalLBVSStats.pl bigip01 443 username password list (heh, and yes I’m not actually using ‘username’ and ‘password’; I’ve run other iControl scripts just fine).
The iControl.cgi process goes from an RSS of 19 megs to about 150 megs in about a minute and keeps going:
root 17234 0.0 67.4 261316 148620 ? D 04:02 0:12 /usr/local/www/iControl/iControlPortal.cgi
It’ll go as long as you let it. I’ve seen it get up to 600megs of RSS before I had to kill.
We only have 286 virtual so I doubt it can get up to 600megs.
Anybody know what might be going on?
The sample code in the SDK queries stats for all virtuals within one call. Each set of statistics for each virtual can be quite large so querying that many virtuals in one shot could cause issues with server resources.
Give this code a try. I’ve added chunking of the requests and I think you’ll see that your resource issues go away.
!/usr/bin/perl
The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
Software Development Kit for iControl"; you may not use this file except in
compliance with the License. The License is included in the iControl
Software Development Kit.
Software distributed under the License is distributed on an "AS IS"
basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
the License for the specific language governing rights and limitations
under the License.
The Original Code is iControl Code and related documentation
distributed by F5.
The Initial Developer of the Original Code is F5 Networks,
Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc.
Alternatively, the contents of this file may be used under the terms
of the GNU General Public License (the "GPL"), in which case the
provisions of GPL are applicable instead of those above. If you wish
to allow use of your version of this file only under the terms of the
GPL and not to allow others to use your version of this file under the
License, indicate your decision by deleting the provisions above and
replace them with the notice and other provisions required by the GPL.
If you do not delete the provisions above, a recipient may use your
version of this file under either the License or the GPL.
use SOAP::Lite + trace => qw(method debug);
use SOAP::Lite;
use MIME::Base64;
BEGIN { push (@INC, ".."); }
use iControlTypeCast;
Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sCommand = $ARGV[4];
my $sArg1 = $ARGV[5];
my $sArg2 = $ARGV[6];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
&usage();
sub usage()
my ($sCmd) = @_;
print "Usage: LocalLBVSStats.pl host port uid pwd command [options]\n";
print " -----------------------------------------------------------\n";
if ( ($sCmd eq "") or ($sCmd eq "get") )
print " get virtual server - Query the specified virtual server\n";
if ( ($sCmd eq "") or ($sCmd eq "list") )
print " list - List the entire virtual server list\n";
exit();
Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials
return "$sUID" => "$sPWD";
$VirtualServer = SOAP::Lite
-> uri('urn:iControl:LocalLB/VirtualServer')
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $VirtualServer->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
if ( $sCommand eq "get" )
&validateArgs("get", $sArg1);
&handle_get($sArg1);
elsif ( $sCommand eq "list" )
&handle_list();
else
&usage();
validateArgs
sub validateArgs()
my ($cmd, @args) = (@_);
foreach $arg (@args)
if ( "" eq $arg )
&usage($cmd);
checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
sub handle_get()
(@VirtualServerList) = @_;
if ( 0 == scalar(@VirtualServerList) )
return;
Set the default chunk size
$chunk_size = 10;
Set the time threshold per call (in seconds)
$time_threshold = 10;
$total_size = scalar(@VirtualServerList);
for ($i=0; $i<$total_size; $i+=$last_chunk_size)
if ( ($total_size - $i) < $chunk_size )
$chunk_size = ($total_size - $i);
$last_chunk_size = $chunk_size;
Make sure chunk array is empty
@chunk_list = ();
undef @chunk_list;
fill new array
for ($j=0; $j<$chunk_size; $j++)
$val = @VirtualServerList[$i+$j];
push @chunk_list, $val
Get Start Time
$start_time = time();
Make calls
print "Querying $chunk_size elements\n";
&handle_getex(@chunk_list);
Get Stop Time
$end_time = time();
$chunk_time = $end_time - $start_time;
print "Time this section: $chunk_time s.\n";
increment total time
$total_time += ($chunk_time);
if ( $chunk_time < $time_threshold )
$chunk_size *= 2;
print "Total execution time: $total_time s.\n";
get
sub handle_getex()
return;
$soapResponse = $VirtualServer->get_statistics
SOAP::Data->name(virtual_servers => [@VirtualServerList])
&checkResponse($soapResponse);
$VirtualServerStatistics = $soapResponse->result;
$time_stamp = $VirtualServerStatistics->{"time_stamp"};
@VirtualServerStatisticEntry = @{$VirtualServerStatistics->{"statistics"}};
foreach $VirtualServerStatistic (@VirtualServerStatisticEntry)
$virtual_server = $VirtualServerStatistic->{"virtual_server"};
$name = $virtual_server->{"name"};
$address = $virtual_server->{"address"};
$port = $virtual_server->{"port"};
$protocol = $virtual_server->{"protocol"};
print "Virtual Server: '$name' ($address:$port)\n";
@StatisticList = @{$VirtualServerStatistic->{"statistics"}};
foreach $Statistic (@StatisticList)
$type = $Statistic->{"type"};
$value = $Statistic->{"value"};
$low = $value->{"low"};
$high = $value->{"high"};
$value64 = ($high<<32)|$low;
$time_stamp = $Statistic->{"time_stamp"};
print "--> $type : $value64\n";
list
sub handle_list()
$soapResponse = $VirtualServer->get_list();
@VirtualServerList = @{$soapResponse->result};
&handle_get(@VirtualServerList);
Hopefully in future SDK’s we’ll have the samples updated to include chunking by default.
-Joe
That runs for a bit but then ends with “500 Internal Server Error at test.pl line 212” (test.pl being what I pasted your script as). It’ll list about 10 entries before dying (though it says it’s retrieving 20).
Then the following gets printed to /var/log/httpd/httpd_errors:
Nov 1 14:53:26 bigip02 fcgi-[17233]: [warn] FastCGI: server “/usr/local/www/iControl/iControlPortal.cgi” (pid 21348) terminated due to uncaught signal ‘11’ (Segmentation fault)
Nov 1 14:53:26 bigip02 fcgi-[17233]: [warn] FastCGI: server “/usr/local/www/iControl/iControlPortal.cgi” has remained running for more than 30 seconds, its restart interval has been restored to 5 seconds
Nov 1 14:53:26 bigip02 fcgi-[17233]: [warn] FastCGI: server “/usr/local/www/iControl/iControlPortal.cgi” restarted (pid 21511)
Nov 1 14:53:26 bigip02 httpd[6174]: [error] [client 10.1.1.78] FastCGI: incomplete headers (0 bytes) received from server “/usr/local/www/iControl/iControlPortal.cgi”
Which version of BIG-IP are you running? If you are getting server errors with small requests, then this has to be something related to the release you are running. I’ve tested this script on v9.2 with 2000+ VS’s with no issues.
-Joe
Sorry about the delay in the response (I didn’t forget about you!). I’ve just been trying to reproduce it on my end and have yet to succeed.
Are you having any problems with any of the other samples in the SDK or is it just this one?
If it’s just this one, then I’d try changing the chunk_size varaible in the sample and comment out the part where the chunk_size is incremented. That will force a request size of 1 virtual per request. If this still causes a problem, then you will have to open a case with support to get a developer working on it.
-Joe
