I already asked you the question about the problem im having with different version issue.
(http://devcentral.f5.com/Default.aspx?tabid=53&forumid=1&postid=25104&view=topic)
I “thought” the version issue only matter with the iControl library itself.
I “thought” as long as I use the newst version of iControl, I would be fine.
It turns out… I “thought” wrong!
It seems to me, the version of BIG-IP is already set. So no matter what version
of iControl library that I use, I cannot use any of API method which requires
higher version of BIG-IP than the version of BIG-IP that I already have.
In other words, it won’t matter even if I have 9.6.0 version of iControl.
If I have a BIG-IP ver 9.3, then I am not ganna be able to use the full performance
of ver 9.6.0 iControl library. Isn’t that right?
(QUESTION)
HOW DO I UPDATE THE VERSION OF MY BIG-IP SERVER?
(please refer to the attached img)
what do I do? hotfix patch?
