icmp of management firewall
Hello.
I was doing a test on the management firewall.
I don’t want to respond when a client makes an ICMP request to MGMT.
I think I can do it by adjusting the settings in “Security Firewall Management-IP-Rules”, but it doesn’t work.
Any suggestions?
You can use Platform->Security , if you want to deny ICMP to the management IP:
you can also have a look at packet filters if you want to filter on different interfaces/vlans:
Dear mihaic
First all, Thank you for your Solution.
Unfortunalluy, I did its config.
but not working :cry:
It seems this is bug https://cdn.f5.com/product/bugtracker/ID760355.html
try this:
Dear mihaic
Thank you so much!
I have a personal question.
The only thing that can answer this is…
A reference? Or is it a search skill?
search in this case
