I have couple of VIPs created by template “f5.microsoft_sharepoint_2010”.
All these VIPs are created with web acceleration profiles (caching profile)
all these profiles has no filter of objects going to be cached, only “include list” contains “.*”
Is it proper setup? I would suspect there some list of objects which are going to be cached, but there is no exact specification. I checked cached objects via command “show ltm profile ramcache xxx” and found out mostly png and javascripts are cached. Do you know if some default list of cached objects exists? I could not find it yet..
Also we have about 30 web-acceleration profiles and we are having RAM problems in the same time. I know that consolidating profiles is worth when there is used WAM or AAM acceleration module (saves RAM usage). Do you think it is worth to do also in case we are using LTM caching? (without provisioned WAM/AAM)?
Many thanks, Zdenek
