Is iApps Citrix template supported on Azure appliance? I got problem because of shared NIC.
Hi magnus78,
Can you add a little more detail regarding the problems seen while using the Citrix iApp in your azure environment? Also, check out this document as it discusses how to handle multiple applications using the same port in Azure. Note the Citrix iApp, in advanced mode, will allow you to modify ports for each VS created by the iApp.
